SH-101 filter problem
craggno
Post by craggno » Sun Apr 06, 2008 3:59 pm
It appears that the filter is not working....it is behaving like the filter cutoff is having no effect. I suspect the IR3109 chip is dead (although I don't have the ability to test this per se) everything else is working fine. Does anyone know where someone could buy a replacement filter? Thanks for your help. I have searched all over the internet and am beginning to panic a little.
Thanks
Spectralis, Modular Keyboard, MKS-80/MPG, Alpha Juno, MS-20, Minimoog, SH-101, Microwave I, DX7, Midi-Talking Synth, MBase 01, Machinedrum SPS-1, Sidstation, Kenton Pro 2000
plus321
Post by plus321 » Sun Apr 06, 2008 6:42 pm
Check your slider. I think if the filter chip was dead you would hear nothing at all since the signal is hardwired through that chip.
Try to crank up the resonance and/or use a negative envelope and see if you can get the cutoff to change.
sam
Post by sam » Sun Apr 06, 2008 6:53 pm
Just check the slider and it's not that often those chips fail.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
