Hello fellow synth lovers!
I just got an E-synth classic (to upgrade from my E64), and there are no power cables for the internal drive...
It looks like there is a 4 pin connector on the MB to install some kind of cable for that. Does anyone have either:
1- Have an idea what I'm talking about.
2- Have some kind of specs on the cable I need.
I have the flat 50pin SCSI cable for the drive, which was in the E64. But for some reason, E-mu decided to make the E-Synth (and probably the E6400 as well) differently from the original E4 and E64.
Thanks!
E-mu E-Synth Dance internal HD cables
- Spadz
- Real name: Francis
- Gear: Synths, samplers, guitars, bass, drum
If you don't know what you are doing, why are you doing it?
