Sorry for another lithium battery post - but my query is a little more specific than ditabeardmemo's.
I need to replace the battery in my recently acquired MSQ-700.
I found a post on Analogue Heaven stating that the Roland part number is 12569140 - EP-6 lithium battery.
Can I just replace it with any old lithium battery that's the right size or do I need the specific Roland part?
Also, does anyone know where I can get my hands on a service manual for the MSQ-700. Alternatively, can anyone give me instructions how to change the battery?
Regarding the mains voltage, the plate on the back panel states that the unit is AC 117 volts - do I need a step down converter?
Many thanks in advance- any assistance is greatly appreciated.
MSQ-700: Replacing lithium battery & AC 117 volts questi
lost cause
- Gear: Tons of softsynths, JU-60 & Pro DCB Mk3, MSQ-700, XV-2020 & SRX-07, KMS-30, K2000
Hardware: Juno-60, Pro DCB Mk3, JD-990, XV-2020 & SRX-07, MSQ-700, LinnDrum & Forat midi, OB DX & Electrongate midi, Korg KMS-30, Kurzweil K2000, BCR2000
- nathanscribe
- VSE Review Contributor
Are you in the UK? If so, yes you'll need a step-down convertor. Maplin sell them, but beware the cheaper 40W ones, they're unreliable in my experience (been through 3 of them on different bits of gear). The 100W ones are sturdier and quieter. Maplin's are overpriced though, try Rapid Online. I use them a lot.
It might be that there's a voltage switch inside though - I'm not sure about this particular unit. Some gear just has a slider to set the voltage to 120/240, might be worth checking. That would be in the service manual. Don't have one though, so can't help there.
lost cause
No, I'm not in the UK, but the mains AC voltage where I am is 230.nathanscribe wrote:Are you in the UK?
No, there isn't a switch on the back of the MSQ-700 to select voltage.nathanscribe wrote:It might be that there's a voltage switch inside though - I'm not sure about this particular unit.
Many thanks for clearing that up for me!
