Roland RS-70 (Juno-D too?) Key Mode question...Newbie
Paul Days
Post by Paul Days » Sun Jun 15, 2008 4:17 am
The manual on this thing doesn't help out too much. When I Select "Key Mode" and Split the sounds, I get on the Left side (bass) the standard gran piano patch. How on earth do i change that patch to whichever i want?
I've flipped through, but no luck.
Thanks in advance.
Paul
Paul Days
ANSWER
Post by Paul Days » Sun Jun 15, 2008 6:20 am
Ok, A fellow RS owner responded for me, for archival and search purposes, here it is:
in the EDIT pane, select PARAM.
in the PATCH MODIFY pane, select the DESTINATION TONE, UPPER OR LOWER.
Then select the PATCH NUMBER you want.
Hope this helps at some point.
Cheers,
Paul
