Monomachine blowing fuses:
mome rath
Post by mome rath » Thu Jul 10, 2008 8:48 pm
A friend of mine opened up his MnM to peak around at an issue with an output. After closing it back up, it now blows a fuse every time it's powered on.
Now it lives with me, and I'd like to see if anyone has any insight before I:
  • a) take it to a local tech and forfeit $25 for an estimate and potentially no fix, or
    b) send it to the Elektron guy in the USA to the tune of ~$300 for diagnosis/repair.
We've not found anything regarding which fuse to put in the MnM, so dude got some at Radio Shack and I've been blowing those up one by one.
I saw a place where a (missing) screw mounts the PCB to a small internal ledge on the chassis, above the far right (looking down into the open MnM) outputs. I thought that could be a chassis ground, so I tossed a new screw in that and just ended up blowing another fuse when I turned it on again.
halp! :?
god elton can't you suck
Altitude
Post by Altitude » Thu Jul 10, 2008 11:29 pm
Standard drill, take a meter out and start probing for shorts to ground or chassis starting at the power inputs on back... Something must be touching, I would be surprised if a component blew
plus321
Post by plus321 » Fri Jul 11, 2008 12:03 am
Test the diodes in the PS.
I have a Prophet 2002 and it would blow a fuse immediately each time I turned it on when I first got it. The problem was a diode.
So you can't reliably test a diode in-circuit, but if it is worth a shot before removing them to test.
If you have a meter, then it will only take you a moment to check that they are fine. It sounds like it is probably something else though since it only happened after it was opened.
