yup, simple logic can get you quite far. ive sourced bad ic's in synths before, even when i had NO idea what the pin voltages SHOULD look like, merely by comparing all the same chips in the circuit.
also, another tip. contrary to public opinion, im not aware of any synth that actually carries lethal voltage/amperage, but nevertheless, amp techs have a technique that keeps you safe:
if you are using a voltmeter, clip the - lead to a ground in the synth, and then when poking with the + lead, use ONE HAND. if you can avoid current travelling from one hand to another(think about it-right thru your heart), you severely decrease your odds of a serious injury.
DIY Synth Repair
- adamstan
- Real name: Adam
- Gear: Yamaha 2xDX7II|QY-70|PSR-S750|PSR-2000|TYROS|Electone D85|Electone E50
B5 DIY polysynth
KORG Poly61
Vermona DRM
Solton Programmer 24
LEMA EDD-5 - Location: Poland
Any synth with built-in power supply will have points that are connected to mains voltage, and often these points are accesible. If you keep away from power supply however, you are safe in most cases - actual synth circuits are mostly indeed low-voltage, with +-15V max.rjd2 wrote:contrary to public opinion, im not aware of any synth that actually carries lethal voltage/amperage,
Man with a tape recorder | Living in the '80s
sorry, should have qualified that-im in the US. maybe your 240 is dangerous(although i have gotten bit by that too), but a 110 bite is nothing. got one this morning!adamstan wrote:Any synth with built-in power supply will have points that are connected to mains voltage, and often these points are accesible. If you keep away from power supply however, you are safe in most cases - actual synth circuits are mostly indeed low-voltage, with +-15V max.rjd2 wrote:contrary to public opinion, im not aware of any synth that actually carries lethal voltage/amperage,
- th0mas
- Expert Member
- Band: GRAVITRONIC
That is really really stupid advice. 110 can easily be lethal. That's stupider than welding your synth. It's not the volts, its the amps.rjd2 wrote:sorry, should have qualified that-im in the US. maybe your 240 is dangerous(although i have gotten bit by that too), but a 110 bite is nothing. got one this morning!adamstan wrote:Any synth with built-in power supply will have points that are connected to mains voltage, and often these points are accesible. If you keep away from power supply however, you are safe in most cases - actual synth circuits are mostly indeed low-voltage, with +-15V max.rjd2 wrote:contrary to public opinion, im not aware of any synth that actually carries lethal voltage/amperage,
