HELP!! No power to desk
leonidspaul
Real name: Paul
Gear: M1, Alpha Juno 1, Juno 106, TR606, 707, Poly 800, Poly 800II, SH09, MAM MB 33, Midas Venice 320...
Post by leonidspaul » Mon Sep 01, 2008 7:25 pm
I was ready to mix the final track before sending it off to the pressing plant and this happens. Just as i go to power on my Allen and Heath GL2200, there is no life in her. If there are any people with electrical knowledge please please i need your help. Is this likely to be something i could fix myself or does it sound more serious?? Thanks... Paul
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Re: HELP!! No power to desk
Post by Maschinengeist » Mon Sep 01, 2008 8:24 pm
First, check the fuse. A visual inspection may reveal the problem, especially if the glass is spotted. Replace by the same value (printed on the metal cap). Otherwise, use a multimeter and set it to OHM. If your fuse offers resistance, it is blown.
If the fuse is ok, it may be the switch or the power supply. Then it might take a tech to inspect it. It could be a lot of things from defective transformer, diode, voltage regulator, etc.
I don't currently have the service manual nor the schematics. But I've just my suppliers and they can find me one.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
leonidspaul
Real name: Paul
Post by leonidspaul » Tue Sep 02, 2008 9:18 pm
Thanks a lot Maschinengeist. I took the fuse out and it was blown. i feel very relieved. Appreciate the advice!!! Paul
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Wed Sep 03, 2008 1:02 am
Isn't it great when it's just something that simple?
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Wed Sep 03, 2008 1:43 am
leonidspaul wrote:Thanks a lot Maschinengeist. I took the fuse out and it was blown. i feel very relieved. Appreciate the advice!!! Paul
My pleasure Paul.
Funny story: some of my customers took their gear to a tech (hey, the damn thing no longer work!) and they had one big bill (hey, the techs have all their policy, like 1 hour min.more or less). Not to say that they are dishonest (hey, I am a tech!). Myself had a problem at my house and had to call a professional. Cost me $85 + taxes for less than 15 m work (and it turned out to be a little stupid thing... but I didn't know what the h**l was wrong).
MuzikElektronix.com
Help? See TechZone
Parts? email!
leonidspaul
Real name: Paul
Post by leonidspaul » Wed Sep 03, 2008 5:22 pm
Well do i feel stupid?!! I was a bit hasty in my reply, yes the fuse was blown but i just replaced the old fuse with exact same new fuse and the same thing just happened. Thinking it might be the IEC lead i switched that replaced the fuse again and the same. The green led power light turns on, then there's an audible hum and then lights out. I'm thinking i will have to get a service no?? Frustrated...
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Wed Sep 03, 2008 10:33 pm
You don't have to feel stupid. Sometimes, just changing the fuse once is enough.
But if your hear a hum + multiple fuse blow, the power supply is to be verified by a professional. Chances are that the transformer and possibly a power transformer are problematic (to name just those two).
Don't venture there if you have no electronic knowledge. There is high voltage there which could harm if not kill you.
Oh, I just received the service manual with schematics too (if in case your tech doesn't have it already).
MuzikElektronix.com
Help? See TechZone
Parts? email!
leonidspaul
Real name: Paul
Post by leonidspaul » Thu Sep 04, 2008 7:00 pm
Yeah i'm going to send her off, i'd probably end up causing more damage if i went messing around with it. On the plus side though, i'll be getting a loan of a Midas Venice so it's not all bad news! I'll find out if he has the schematics and if he doesn't i'll grab them from you. Thanks very much. Paul
cornutt
Gear: 6th
Post by cornutt » Sun Sep 07, 2008 12:13 am
My guess is that a filter cap in the power supply is shorted. If that's what it is, it's not a hard thing to fix; however, if you aren't familiar with working with line-voltage circuits, it's not a good thing to mess with. Assuming that the PS isn't hard to get to, it should be fairly straightforward for a tech to fix it.
