Jupiter 6 envelope problem
atari5200
Post by atari5200 » Sat Sep 27, 2008 1:05 am
For some reason, envelope 2 on my Jupiter 6 is acting strangely. When the release setting is between 1 and 4 I get a weird metallic sound when I release a key. The sound is hard to describe but it's almost like a metallic sounding "shnk". Vaguely similar to a higher pitched version of the sound pac-man makes when he eats power pellets. It is not as loud as the synth sound itself, it's much more faint, but it is loud enough to be audible when I record. When the release is set above 4 the sound disappears, and, (as I know is common on analog synths and is not the reason I'm posting this) when the release is set to 0 I hear a slight click. This click is not an issue as I know it's normal and I also don't program too many sounds with 0 release, but the lack of being able to set the release between 1 and 4 is annoying. Is this normal or is there something wrong with my envelope? Setting the attack, decay or sustain to a low number does not cause any strange artifacts, it's only the release setting. As the Jupiter 6 doesn't allow me to route envelope 1 to the VCA I can't test whether or not the other envelope is exhibiting the same issue. Do I just need to suck it up and always have my release set above 4 or is this a fixable problem? I have a guy who has worked on my synths before but it will sit in his shop for weeks until he can even look at it and even that will cost me $$. Any advice or words of wisdom would be appreciated. I also have a smaller issue with my Korg Mono/poly but I'll save that for another day!
Thanks in advance for your assistance-
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Re: Jupiter 6 envelope problem
Post by Maschinengeist » Sat Sep 27, 2008 4:57 am
I cannot answer right away. Let me dig up my service manual and look at it as soon as finish some businesses.
I'll try to come back to you asap.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
atari5200
Post by atari5200 » Sat Sep 27, 2008 1:10 pm
Great, I appreciate your help.
Additionally, as I forgot to mention in my original post, the Jupiter is a stock model, it doesn't have the Europa upgrade or any other type of mod for that matter.
Thanks!
-Nate
atari5200
Post by atari5200 » Mon Nov 03, 2008 6:24 pm
*bump*
