roland d-50 noise problems
mikac
Post by mikac » Wed Oct 01, 2008 9:01 pm
Hello everybody.I just bought my d-50 a few months ago,and at first everything was ok,than after a while I noticed that every time the key is pressed ,I hear the noise that goes along with the sound,and fade away with it.It is not loud,but it could be easely heard if you listen carefully.The noise appears with every sound.I tried to turn off the chorus,reverb...and verified each oscilator seperately.The noise was still there.Than i sent d-50 to someone who repairs all kind of keyboards,but he is not specialized in roland.He could not find the error.If anyone knows the solution,i would be very grateful.Please help.
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Re: roland d-50 noise problems
Post by Maschinengeist » Thu Oct 02, 2008 4:36 am
A few things can provoke "noise".
Questions:
1) Can you describe the "noise". Is that a crackling, a hissing, low-pitched? Different components do different "noise" when defective. It can be a transistor, an op-amp, an IC, a capacitor, etc.
2) Does the noise hearable in both outputs, just in one (which?), can it be heard also be heard from the headphone?
Generality: *usually" the low-noise op-amps used in the D-50 go south. BUT it's not because some have this problem that everyone has that problem. But, considering its age, it's about normal that they become less "low noise" now.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
mikac
Post by mikac » Thu Oct 02, 2008 9:07 am
Noise is low-pitched and it can be heard from both outputs + headphones.
The noise is more affective on longer sounds,on shorter which have none release,is hardly noticable.
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Thu Oct 02, 2008 5:11 pm
Is it like hissing white noise or like humming? If it's humming noise, it may just be bad audio cables.
