Minimoog Oldschool Your thoughts on the Enveloppes
Alphacode
Post by Alphacode » Wed Nov 12, 2008 5:09 pm
Hi Everybody
How do you find your Enveloppes in your Minimoog OS ? I found them to not be as snappy as i expected . Within a week of getting it i wrote an email to Moog and got an answer on how to tweak the synth inside to get them to work faster. And i have to say the results are impressive . They work a lot better now .Have more punch on the attack and decay.
Any of yous tweaked their Voyagers ? Anybody can name what all the Potentiometers insde do ? i know what 3 of them do so far... But i wanted also the Filter ADSR to act more on the filter without using the mod buses.
Regards
Sir Ruff
Re: Minimoog Oldschool Your thoughts on the Enveloppes
Post by Sir Ruff » Thu Nov 13, 2008 2:49 am
can't comment on this directly, but it's interesting (and nice) to know that a) you can actually tweak the insides to get a better response, and b) moog actually helped you do it!
by making the envs faster, did that decrease their maximum attack/decay times somehow?
Do you even post on vse bro?
xpander
Post by xpander » Thu Nov 13, 2008 3:13 am
the envelopes on my voyager os do not need tweaking whatsoever; maybe your OS went out of calibration or was just setup differently.
Alphacode
Post by Alphacode » Thu Nov 13, 2008 10:34 am
Yes it did shorten a little bit the attack and decay but prior to do the tweaks i checked and the decay for example on his max setting was actually over 10s long and it is now around 10s so maybe it wasn't calibrated properly after all . Moog was brillant they told me also how to change the pitch bend range on the wheel ...
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Fri Nov 14, 2008 5:07 pm
The pitch bend mod was a quite normal one on original Model D minimoogs too.
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Sat Nov 15, 2008 12:32 am
Well the envelopes on the Moog LP Tribute are probably the snappiest I've ever heard. The Juno-6 is the only other synth that I can remember even coming close.
