Roland R-70 Bad Outputs
Hellhound
Gear: Novation Bass Station Rack, Roland R-70 Drum Machine, Alesis Midiverb II, Akai S2000 Sampler & Mackie 1202 VLZ Pro.
Post by Hellhound » Tue Nov 25, 2008 9:43 am
Hey guys. I recently discovered that the right stereo output and both individual outputs don't work properly on my R-70. The right output is really quiet and the two individual outputs are even quieter and hum.
Does anyone know how I could fix them?
Da funk back to the punk!
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Re: Roland R-70 Bad Outputs
Post by Maschinengeist » Wed Nov 26, 2008 7:52 am
Surely a dying op-amp (the usual thing).I'll check my document and I'll come back to you.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
wiss
Post by wiss » Wed Nov 26, 2008 9:48 pm
I am going ask a really dumb question.......did you go thru the external mixer it has and put everything in stereo and check the volumes...I'm assuming it's set up like the r5 and r8
Hellhound
Post by Hellhound » Thu Nov 27, 2008 8:17 am
Yeah, I have checked the internal (thats what you meant right?) mixer. I have every thing at full volume. Thanks for the suggestion though.
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Thu Nov 27, 2008 8:06 pm
Assuming that eveything outside the R-70 works as they should: mixer board, cables, amp., and that the jacks are not as loose as a crack w***e, the problem can come from IC2 (uPC4570C)- which drives the 3 outputs. But it is also possible that there is another problem along the chain. Because each outputs are driven their own digital transistor (DTC343TK). Note: it might the parts themselves that are going south. But it is also possible that they are not properly fed - which means that the problem comes further up (like bad voltage, etc).
MuzikElektronix.com
Help? See TechZone
Parts? email!
Hellhound
Post by Hellhound » Sat Nov 29, 2008 8:12 am
Thanks for the reply Maschinegeist. Do you know where I can find a service manual for the R-70? With it I might be able to open it up and pinpoint the problem.
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Sat Nov 29, 2008 8:20 am
Hellhound wrote:Thanks for the reply Maschinegeist. Do you know where I can find a service manual for the R-70? With it I might be able to open it up and pinpoint the problem.
Check my signature closely: I have it, complete & clear & in PD. Please refer to the list. You can also see my website "the Boutik" section.
MuzikElektronix.com
Help? See TechZone
Parts? email!
