Sync Microkorg arpegiator w/ DDD1
die monster die
Real name: Pierre
Gear: MS10, Monopoly, Synare S3X, Microkorg, DDD1, Prodigy, UpOne, MFB502, Mopho.
Post by die monster die » Tue Mar 03, 2009 7:02 pm
Hey;
I bought a Microkorg to make my gear easier to set up. I'd love the arpegiator to work with my an oldschool Korg DDD1.
I have both manuals but i can't make them behave as master/slave.
DDD1 is:
Midi out cabled
Clock Internal
Midi Receive: Unavalaible
Midi Transmit : Available
Instrument data transmit: K=01 (kick drum = channel one)
DIP switch 4 (protect) is off.
Microkorg is:
Midi In cabled
Midi Channel : 1
Local On
Clock : External
My midi cable works, i can control the DDD1 with my Master Keyboard.
Looks like no tempo is received.
Do i do smthg wrong? Can't they work together?
Actually, it seems the instrument i select for data transmit is not kept in memory everytime i go back to Pattern.
I have no clue what to do.
Anybody?
Re: Sync Microkorg arpegiator w/ DDD1
Post by meatballfulton » Tue Mar 03, 2009 7:27 pm
The missing piece is whether or not the DDD-1 can send MIDI clock. What does the MIDI implementation chart say?
Clock is not channelized, so the channel settings don't matter.
Instrument data transmit would be used if you wanted the DDD-1 to play the kick drum part on an external device (like the MK). In your application you have no reason to use it.
die monster die
Real name: Pierre
Post by die monster die » Tue Mar 03, 2009 9:15 pm
Mmmm... thanks!
I'm a newbie with MIDI...
Here is a link to the owner manual: http://www.synthdiy.com/show/?id=1147
Midi implantation is p.138.
It looks like chinese to me...
'Timing Clock' (Note 4) is this what we are looking after?
die monster die
Real name: Pierre
Post by die monster die » Fri Mar 06, 2009 4:13 pm
Mmmm,
I tried the other way around, i.e controling the tempo of the DDD1 from the microkorg.
Set the DDD1 clock to "midi"... It doesn't work either.
Is it hopeless?
