hi
still need some tech-type help on CZ-1 powersupply voltages: on all schematics - except the PS - the neg analog supply is labeled -15 volts. on the PS schematic, it is clearly labeled -7 volts... which is correct??? Powered up, the line falls to -3.5 volts, killing the analog side.
2. anybody have 3 slide-knobs for a Yam. CS20 they would sell??
thanks
help: cz-1, cs20m
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
help: cz-1, cs20m
- Confucius
- Confucius
