The 3rd osc will not scale....It's as flat as a pancake..
Where should i be looking...?
MIDIMOOG osc problem
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
- pflosi
Re: MIDIMOOG osc problem
first, make sure you enable osc 3 keyboard control, which can be disabled to have the same lfo rate all over the keys if the 3rd osc is used as lfo...
Cheers but thats not the problem....It's something technical i need to find..pflosi wrote:first, make sure you enable osc 3 keyboard control, which can be disabled to have the same lfo rate all over the keys if the 3rd osc is used as lfo...
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
- hfinn
- Expert Member
- Gear: http://soundcloud.com/heath-finnie
Keep in mind it could be a bad switch. I had a mini that had bad switches (some of them just switching it back and forth a bunch helped). Sometimes those switches can oxidize.sam wrote:Cheers but thats not the problem....It's something technical i need to find..pflosi wrote:first, make sure you enable osc 3 keyboard control, which can be disabled to have the same lfo rate all over the keys if the 3rd osc is used as lfo...
The switches are pretty awful and i will do a clean up of these..hfinn wrote:Keep in mind it could be a bad switch. I had a mini that had bad switches (some of them just switching it back and forth a bunch helped). Sometimes those switches can oxidize.sam wrote:Cheers but thats not the problem....It's something technical i need to find..pflosi wrote:first, make sure you enable osc 3 keyboard control, which can be disabled to have the same lfo rate all over the keys if the 3rd osc is used as lfo...
All the voice boards are the same, I will change them around to see if it's just the board...
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
- madtheory
- Real name: Tomas Mulcahy
Hi sam. That's a damn nice synth. It is incumbent upon you to post pics of your setup!
How do you post photo's on here..?madtheory wrote:Hi sam. That's a damn nice synth. It is incumbent upon you to post pics of your setup!
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
- HideawayStudio
- Real name: Dani Wilson
- Band: Shortwave
Yes please... and if you do open it up, any chance of posting a piccy of it's innards in my synth guts pictures thread??madtheory wrote:Hi sam. That's a damn nice synth. It is incumbent upon you to post pics of your setup!
http://www.vintagesynth.com/forum/viewt ... synth+guts
You simply click on upload attachments at the bottom of the edit post window, then browse for your file and then click on add file. You can then embed the piccy in your message once loaded. You might need to reduce the size of your picture by scaling it down in Paint etc before it will successfully load.
H.I.D.E.A.W.A.Y S.T.U.D.I.O
http://www.hideawaystudio.net
The Home of Novachord #346
http://www.novachord.co.uk
