TAP TAP mc202
TAP TAP mc202
what do the 2 TAP buttons do onthe mc202? are they like the tb303 TAP write?
- TrondC
- Gear: Machinedrum UW & Monomachine Mk2's
Korg KP3 & Zero 4 - Band: Siesta Submarina
Re: TAP TAP mc202
1.google.com
2.user manual
3.try and see what happens?
2.user manual
Re: TAP TAP mc202
Hi, do you have a mc202?
- TrondC
Re: TAP TAP mc202
no I don't actually, but I do know that every function of every synth (maybe except some oddballs) are explained in it's user manual. a quick google should find you a scan of the manual or something similar.
did you try using the tap-button and see what happens?
Re: TAP TAP mc202
yes ive tried using the tap, im sure there are mc202 users who use this forum..
- Syn303
- Expert Member
- Gear: Quite a bit...
- Band: Syn303
Re: TAP TAP mc202
those TAP buttons on the bottom right have 2 functions.
in step-write mode (press the EDIT button), they are for inputting ACCent and PORTAmento (slide).
in real-time mode (SHIFT + NORM button), allows you to TAP in notes in real-time while the metronome sounds.
it also allows you to step through note/pitch data with the TAP key in EDIT modes.
if you don't have a manual - get it here: ftp://ftp.roland.co.uk/ProductSupport/M ... 202_OM.pdf
