When I wrote that, I was thinking that the MS20 had a duophonic keyboard. I've since realized that it doesn't. Sorry about that.Hybrid88 wrote:Yes, well I was kinda thinking that but then why would OSC2 not work at all?cornutt wrote:My only other guess at this point is that it has something to do with the keyboard interface circuitry.
Korg MS-20 - no oscillator sound?
- cornutt
- Gear: 6th
Re: Korg MS-20 - no oscillator sound?
Steve Jones
- Real name: Steve
I see MS-20's come in all the time with VCO 2 dead or intermittent due to patch bay contacts. Also, sometimes it is not that the VCO is dead, but that due to a CV issue it is running fine, but above or below audible frequency range.
- Hybrid88
- Gear: V-Synth, and other stuff...
Hey steve, could you explain further, what do you mean by dirty contacts? How would that affect the signal? What are the points to clean?Steve Jones wrote:I see MS-20's come in all the time with VCO 2 dead or intermittent due to patch bay contacts. Also, sometimes it is not that the VCO is dead, but that due to a CV issue it is running fine, but above or below audible frequency range.
In any case, could you say either way if you will be able to look at it? Like I say I'm not in any great rush so to speak, but I really do need to know if you can look at it at some point so I know whether to get ready to send it soon or not. It doesn't have to be straight away but a time frame would be good. I've also got other synths that I'd like to send to your shop so I need to get onto that at least this year for sure.
Thanks mate.
Steve Jones
- Real name: Steve
The little normaling contacts in the patchbay sockets can get dirty and intermittent, usually VCO 2 starts getting erratic and then cuts out. I can take a look for you but I have some big polysynths to restore first so I can't take new jobs until I have cleared them out... it could take 4-6 weeks.
- Hybrid88
Ok, thanks Steve. Consider me on the waiting list for some jobs then, I'll get back to you in about a month or so and see how things are then.Steve Jones wrote:The little normaling contacts in the patchbay sockets can get dirty and intermittent, usually VCO 2 starts getting erratic and then cuts out. I can take a look for you but I have some big polysynths to restore first so I can't take new jobs until I have cleared them out... it could take 4-6 weeks.
Cheers.
- hfinn
- Expert Member
- Gear: http://soundcloud.com/heath-finnie
If it's a bad jack contact that could be a pretty simple fix once you get the thing open.
- Hybrid88
Yeah, I'll try one last time to see what I can do I don't really know how to "fix" a bad contact, apart from cleaning it I suppose - if it doesn't work I'll be sending it to Steve.
Cheers.
Cheers.
- pflosi
hmm... if it's a bad contact in the patchpanel, what happens if you plug "kbd cv out" to "osc cv in" (or whatever it's called, the "normal" hz/v input...)?
- Hybrid88
An image to make things clearer (not mine),pflosi wrote:hmm... if it's a bad contact in the patchpanel, what happens if you plug "kbd cv out" to "osc cv in" (or whatever it's called, the "normal" hz/v input...)?
Well, I did patch an audio signal (just to see what happened) into the "VCO 1+2 CV In" and "VCO 2 CV In" under the volume knob, and while the other Osc1 waveforms suddenly worked, OSC2 was still dead even when trying it with both the inputs I mentioned above.
I'll have to try it with the MS's internal keyboard patched to CV in's when I get the bottom back, it's in bits at the moment so it's not really possible now.
I'll post back later when I've tried it out.
