Using the Moog filter on other synths
- gearfixer
- Gear: ARP Pro DGX, Avatar, EX 800, RS101, VK-8M, Juno 60, 200a, Fast 5, and Rhodes MK1 stage 73.
I would like to run my RS101 and or Farfisa Fast Five through the filter on my Moog Rogue or ARP Avatar but the gain seems to be lacking compaired to the on board osc of either mono synth. Is there a way to get the signal to equal the synth osc level.
Re: Using the Moog filter on other synths
Perhaps run it through a mixer with a Tip/Ring insert jack and pre-amp on the channel, but use a mono cable, so it only sends. Or for a Tip/Ring Insert cable, the synth output goes out on the ring line. Most relevant here is using the mixer channel's pre-amp to boost the level of the source sound. Make sure the synth has a way to completely mute the oscillators. Sometimes even with a pre-filter mixer, the minimum oscillator volume still produces faint droning.
--Solderman no more.
