question re cv/gate on voyager OS
I am considering getting a voyager OS and wanted to control it via cv/gate out from an mc202, does anyone know if some sort of voltage converter interface is required to go from roland to moog? I have to use an interface (ms-02) to control the korg ms20 and just wondered if the same is required for moog.
- shaft9000
- Real name: Dave
- Gear: Whips chains and a contract.
Re: question re cv/gate on voyager OS
Korg is Hz/Volt (unusual) while the Voyager is 1V/oct (more common)
.svc350.memotron
.svc350.memotron
