Roland TR-707 midi question
disco magnet
Gear: Korg MS-10, Korg Microkorg, Korg EA1, Yamaha DX-21, Novation X-station, Roland TR-707, Roland R-8, Roland R-5, Boss DR-55
Post by disco magnet » Mon Sep 13, 2010 10:40 pm
hi,
does anyone know if it is possible to transmit midi and hear the 707 sounds at the same time and if so how?
i've started messing about on it and can't remember what it can and can't do.
cheers
disco magnet
Re: Roland TR-707 midi question
Post by disco magnet » Mon Sep 27, 2010 7:42 pm
just bumping incase anyone can help.
basically i want to transmit a midi pattern and hear the drum sounds to that same pattern too.
thanks
sequentialsoftshock
Real name: Zayne
Gear: Pro One, Analog Keys, Prophet 5, MPC60, TR606, RD8, St. Vincent Guitar, Bluesbreaker amp
Post by sequentialsoftshock » Mon Sep 27, 2010 7:45 pm
In the 2 weeks between posting and bumping, have you tried it??
If it's anything like the 505, then it should. Just make sure the midi channel is the same on the 707 as the unit used to trigger it.
disco magnet
Post by disco magnet » Tue Sep 28, 2010 6:25 pm
hi
yes i posted on here after trying to do it originally.
still no sound when in transmit mode. i've checked the manual but doesn't make it any clearer.
jeeroj
Gear: sh-101, x0xb0x(x2), tr-606, korg es-1, half dead mc-303 and some boss micro racks
Post by jeeroj » Tue Sep 28, 2010 6:29 pm
so you want to listen to the sound from the unit and trigger another unit at the same time?
i'm certain you can do that on a 707 in normal mode. have you set the other units midi channel?
Debut Album out now jeeroj - Selected Acid Works 08-11
check the review HERE first
