Simple (Mono) Analogue Synth which is good MIDI controller?
Re: Simple (Mono) Analogue Synth which is good MIDI controll
The MEK supports poly, so I would assume the Mopho does the same. If I plug the MEK to a poly VA, it works fine.
- sequentialsoftshock
- Real name: Zayne
- Gear: Pro One, Analog Keys, Prophet 5, MPC60, TR606, RD8, St. Vincent Guitar, Bluesbreaker amp
Hasn't the midi standard supported with poly since day one?
Someone please correct me if I'm wrong, but I think that monophonic midi keyboards do exist, like the Doepfer's MKE system. http://www.doepfer.de/MKE.htm
- th0mas
- Expert Member
- Band: GRAVITRONIC
Id assume so too but without having tried it or read it explicitly in the manual I wouldn't confirm it in my message.sequentialsoftshock wrote:It sends poly through the poly chain, which will act as a second midi out when not engaged, so I'd assume it does send polyphonic midi. Also, the board itself is MoPho, but a Tetra can be added to produce five voices.
Yes, but that doesn't mean every MIDI keyboard sends >1 note at a time over MIDI.sequentialsoftshock wrote:Hasn't the midi standard supported with poly since day one?
