Looking for the data from the cassette but can not find it does anyone have the mp3?
Thanks
PolySix Data cassette
- space6oy
Re: PolySix Data cassette
i just landed a copy of the tape. haven't transferred it yet though. bug & remind me.
- Hybrid88
- Gear: V-Synth, and other stuff...
Here you go, Polysix sounds for your synthy pleasure;
http://analog.no/cms/index.php?option=c ... &Itemid=26
- gearfixer
- Gear: ARP Pro DGX, Avatar, EX 800, RS101, VK-8M, Juno 60, 200a, Fast 5, and Rhodes MK1 stage 73.
I've tried these but they did not work are the wave files only suppose to be 3-4 seconds long?Hybrid88 wrote:Here you go, Polysix sounds for your synthy pleasure;![]()
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
I think (?) they are RAR files. you need to un-pack them first with winRAR program.
- Confucius
- Confucius
- gearfixer
The files are compressed but when I unpack them they are only 4 and 3 seconds long.rhino wrote:I think (?) they are RAR files. you need to un-pack them first with winRAR program.
- madtheory
- Real name: Tomas Mulcahy
I've had this issue with a variety of machines, you have to get the input level to the synth right. Try saving from the synth first to see what level it wants, or check the manual?
- gearfixer
I guess 3-4 seconds is a normal length for the transmission because when I saved my patches they were about that long. I still can not load data I've tried volume adjustments but it just does not see the information coming in.madtheory wrote:I've had this issue with a variety of machines, you have to get the input level to the synth right. Try saving from the synth first to see what level it wants, or check the manual?
I have build a new KLM-367 board for the synth that may not be working right.
