How do you find out the part number of a friggin knob?
To the point - anybody know where I can find Lexicon LXP knobs? I don't know that I've ever spotted similar on other gear.
Knobs!
- tallowwaters
- Gear: LC-MS/MS
Knobs!
- nathanscribe
- VSE Review Contributor
Re: Knobs!
Service manuals usually have part numbers for the manufacturer's stock, which may or may not be their own doing. I just get lookalikes from component suppliers. Here in the UK I use Rapid, Farnell, RS, ESR and Maplin, so whatever the US equivalent is. They'll have a few web pages dedicated to knobs. Ahem.
On a more technical level, look for shaft diameter, whether it's splined, serrated (and how many), length, and whether it's grub-screw fixed or push-on.
There's also a noticeable difference between 6mm and 6.35mm (ie, 1/4") - you need the right one. A 6mm knob will generally not push on to a 6.35mm shaft. A 6.35mm grubscrew knob will fix to a 6mm shaft but you'll get cammed rotation.
Could you post a pic of the inside of the knob and the shaft it goes on?
How close are these?
- tallowwaters
- Gear: LC-MS/MS
Re: Knobs!
Your link was on the money, sir.
I tried browsing a few parts places, but it was a pretty daunting task. They almost had more knobs than this forum.
- nathanscribe
Re: Knobs!
Excellent. Those knobs are made by Re'an and should be widely available if you use their own part code. Any trouble, drop me a line.
