I own SH5. All functions work except one thing - every key has same pitch. What can be wrong?
thx
Roland SH5 problem
radek tymecki
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Re: Roland SH5 problem
Quick guess: Most analog monosynths have a jack to patch in an external pitch CV. Usualy, the jack is wired so that when you insert a patch cord the internal keyboard CV is disabled and the external CV is fed to the VCOs. When you remove the plug, the contacts should re-connect the keyboard CV to the oscs. If the jack is dirty, corroded or bent - or a wire is off - this could cause the problem.
- Confucius
- Confucius
radek tymecki
Also make sure VCO2 Kybd-Follow is switched on. Looks like it isn't, in that photo.
--Solderman no more.
radek tymecki
Problem solved. some ic's were damaged on kb-1 board
Nice fix but for the record which chips..?
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
radek tymecki
lm1458 or sth like that
desoldered old ones, soldered new and sh5 works as new
