Search for a sample....
- madtheory
- Real name: Tomas Mulcahy
Re: Search for a sample....
It's the pizz from the Roland JV/ JD series of ROMplers. Easy to sample, there's only one wave it's not multisampled.
clubbedtodeath
- Expert Member
No no. It's a xylophone going through a supersaw filter.
- Automatic Gainsay
- Real name: Marc Doty
- Gear: Minimoog, 2600, CS-15, CS-50, MiniBrute, MicroBrute, S2, Korg MS-20 Mini, 3 Volcas, Pro 2, Leipzig, Pianet T, Wurli 7300, Wurli 145-A, ASR-10, e6400.
- Band: Godfrey's Cordial
How do I get the sound that comes after that sound? The one that sounds like that sound but all echoey?
i need the first sample...CS_TBL wrote:You aren't specific enough, or: what you write can be interpreted in more than one way.
In the clip I hear:
(1) pizzicato
(2) crunchy piano
(3) chick singing 'tonight'
(4) 909 drumkit and probably some unpitched sound effects
(5) some mild 'n low bass, which could as well be the same pizzicato, played in the low octaves
Which sound do you need? Don't say 'this sound', but give us a number.
thanks!
- balma
- Real name: Mauricio
- Gear: DSI Tempest/Prophet 08/Roland V-Synth/Ensoniq Fizmo/E-mu MP7-XL7/Electribe ESX1/Radias/Waldorf MicroQ
Sitbon wrote:How do I get this sound?
THIS I asked...
Ahhhh, yes.
Yes.
I bet is this one:
https://soundcloud.com/balma
- Real name: Unpronounceable
Sitbon wrote:i need the first sample..
And you've been told what it was and where to get it, more than once.
- balma
I suppose it must be hilarious for him to have to fun with people that has good willing to help others on internet's forums. That's the whole intention of this thread....
- Zamise
- Gear: Rollhand P00
- Band: Quantum-Source
Definably a PizzBass, Dsc70H13 canned phrase = 70s Disco House maybe? 120 bpm on my RS7000.
Just save this:
70s Disco House PizzBass
There is also something like a Vox type human voice underneath it with the same chords, like this:
70s Disco House PizzBass /w Vox
70s Disco House PizzBass /w Vox + OB Bass filter sweep
Just save this:
- samuraipizzacat29
- Real name: Nate
Idk what u guys are gettting so worked up about. Mayybe I wasn't clear on my post:
I would use the elevayta extra boy pro and use the spectral-spatial imaging, the spreadilate feature, and select the frequency/pppan areas of the sound you want.
But..... it gets real tricky when the sound you want is in the inaudible frequency range. When its like 23khz or sommething ill sample it (but only with a very high sample rate card of course to prevent aliasing) then ill pitch it down until its in the audible range, tweak it to what I want, then pitch it back up into the inaudible range so I can not hear it again so I can make sure not to get the sound I don't want to have, while maintaining not hearing the sound I do want to have.
And I thought I was a noob....
- Zamise
By the way might be tad dif or a variation but here is the chord structure on it too:
G2 Bb2 D3
D2 F2 A2
G2 Bb2 F3
Eb3 G2 Bb2
F2 A2 C3
Here is midi file too:
Disco House Pizz Midi
If you can't find something to play and edit that you may want to start a new thread, cause I think I can do no more to help recreate base of that lead sample.
Good Luck!
Zam
G2 Bb2 D3
D2 F2 A2
G2 Bb2 F3
Eb3 G2 Bb2
F2 A2 C3
Good Luck!
Zam
