So with a Kenton Pro Solo II, I can make these connections:
PT9 (Profire 2626) MIDI OUT > Kenton MIDI IN
Kenton CV OUT > Mini CV IN
Kenton GATE OUT > Mini GATE IN
Kenton AUX 1 OUT > Linndrum CLOCK IN
Kenton MIDI THRU > Nord MIDI IN
(My mini is modified to have true 1/4" CV/Gate inputs, instead of using S-trig)
…and then I can send a midi sequence from PT9 to both the Nord and the Mini, and send PT9's clock to the Linndrum? And they'll all be in sync?
Kenton Pro Solo II
tomorrowstops
