Tannerin sound?
Shannon U
Tannerin sound?
Post by Shannon U » Sat Aug 11, 2012 11:41 am
Hello all,
New member here asking probably a silly question but need help none the less. I'm looking at an Analogue Systems French Connection but wanted to know what modules I would need to get a sine wave output. I'm really going for a Tannerin sound and figured this would work but if anyone has any previous experiences I would greatly appreciate any advice given.
Thanks once again,
Shannon.
moremagic
Real name: A.M.
Re: Tannerin sound?
Post by moremagic » Tue Aug 14, 2012 2:07 am
most resonant voltage controlled filters would be pretty suitable. at the point of self oscillation the output of the filter alone will produce a sine wave or close facsimile. you could run that thru a vca controlled by an envelope generator, and there you go. getting a vco or two wouldnt be a bad idea, possibly one that works at low frequencies so you can use it for lfo modulation
