another MOPHO question....envelope
- chimney chop
- Band: boxc, cigarettes after sex
how do make it so that the envelope is activated at each key stroke regardless of staccato or legato playing?
- Psy_Free
- Gear: Synths 'n' stuff.
- Band: Klangzeit
Re: another MOPHO question....envelope
Just a quick question. Doesn't your Mopho have a manual with it ? I'm not being funny, but this type of info is in the manual.
Anyway, to retrig the envelopes, you need to set Key Assign to LowRetrig, HighRetrig ot LastRetrig (in Miscellaneous Parameters).
- Stab Frenzy
- chimney chop
i did read it.
i read it through twice actually.
i don't know how to do that on any synthesizer so just seeing that function parameter in the manual wasn't enough.
now that you point it out it seems so clear in the manual but somehow i just didn't see it.
thank you for pointing it out to me though.
