It's been mostly straightforward with regards to getting the thing working. It took a little effort to get it talking to the computer because of the dual midi port requirement, but I was able to jump that hurdle. I'm able to run the editor in Win 7 from my Focusrite Scarlett, and my Novation X-Station is performing controller duties.
I'm able to assign midi CCs from the Novation, but am having troubles with other midi devices doing the same. I've got my JP 8080 set up to transmit midi CCs as well, but am not having much luck with the Nord accepting these. I'm particularly keen to use the JP 8080 as it has more knobs and sliders than the X-Station, I like and am familiar with the layout of this synth. I've tried both Mode 1 and 2 on the Jp 8080 and I'm not sure why it's not working.
I tried to get my DSI MEK to work, and also my Creamware Prodyssey, but no dice. Both these machines will readily spit out midi CCs. I've been trying to assign external controllers via the Nord Modular Editor, but alas, only the Novation is working.
I've looked through the forums at electro-music.com , but can't find anything specific to my problem, and the last post was in July, so not sure how active things are over there. Nord give little information at all except that, yes, you can assign external midi controllers to the G1, via the editor.
If there is anyone who has any idea, your input would be appreciated.
edit/
One thing I forgot to mention, I've been able to send program change messages from the Jp 8080, so I know that midi is being transmitted.
