HELP..
KORG EPS-1
KORG EPS-1
The tremolo is not working...I need the schematics to find which board to look at or has anyone here worked on one..?
HELP..
HELP..
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
Re: KORG EPS-1
I found the board....Can the MN3009 be used as a tremolo or just chorus...?
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
Re: KORG EPS-1
After poking around the board with my signal tracer it started working again...Has not failed on the bench so it's back in the studio for now....
Hmm a bit annoying that i don't know why ..But it works for now.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
- Real name: Unpronounceable
Re: KORG EPS-1
cold solder joint?
Re: KORG EPS-1
Cold solder joint....I don't know in this case as usually it would fail again when it's off for a while. But it keeps on working. I was tracing the signal then it worked but i can't recall where.
With schematics i might of understood more...But for now it works..
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
Re: KORG EPS-1
As a point of interest the EPS has the same string board found in the trident..
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
