Roland Jupiter 50 Cubase programmer here!
gcoudert
Real name: Gilles
Post by gcoudert » Fri Nov 02, 2012 5:48 pm
Hi guys! I don't think there are many Jupiter 50 owners here who also use Cubase but you might well know a man who does. I didn't want to fork out £300 for an iPad so I created my own Cubase programmer in Cubase. Screenshots and download link below.
Limitations:
-Tone 1 only so when you have programmed your tone, save it and move it to location 2, 3 or 4.
-No effects
-No PCM, select them from the synth
On the positive side, you can program all 3 partials at a time, you can access every single Tone parameter other than the aforementioned PCM settings (PCM wave and wave gain) as well as the settings that are common to the 3 partials in the tone.
Enjoy!
Donwload link: http://www.gillescoudert.com/JP50/Roland_Jupiter_50.xml
GC
cornutt
Gear: 6th
Re: Roland Jupiter 50 Cubase programmer here!
Post by cornutt » Fri Nov 02, 2012 6:07 pm
Pretty cool! I've got something sort of like that that I did up in Metro, that I used to program parameters on an E-mu Proteus.
