There is often grease applied on the tipping point of the keys of old synths. In this case it's a VP-330 im fixing.
What should I replace it with? I would think normal grease for mechanics contains acid and such, making it unsuitable for synths.
Silicon grease maybe?
What do you use/think?
What grease on the key tipping point?
- Cybercardinal
- synthRodriguez
- Real name: Scott
- Gear: Moog - Roland - Yamaha
Re: What grease on the key tipping point?
Yes, white silicone grease. Be sure it's of a variety that is safe for plastics; not all are.
I use key guide grease from Yamaha which is Shin-Etsu Chemical Co. type G-30F, Yamaha p/n TX920271. It's pretty low viscosity but seems to work fine for the fulcrums and more importantly, on the key slides where there's lots of movement. Comes in a 100 gram tube (a little smaller than a medium tube of toothpaste). Not expensive as I recall.
Can be ordered online on Yamaha's 24x7 website which is awesome if you already know your Yamaha part number. I order stuff from there all the time. Have to maintain my practice of having more invested in my synths than they're worth, you know...
- Cybercardinal
Thanks!. Yes, I thought silicone grease could do the job.
As I was standing washing the keys, I came to think of Vasoline? But maybe it will melt away because of the heat?
