Closest Hardware Synth to Aalto... or Aalto vs. Mek
- sequentialsoftshock
- Real name: Zayne
- Gear: Pro One, Analog Keys, Prophet 5, MPC60, TR606, RD8, St. Vincent Guitar, Bluesbreaker amp
So, I've been totally digging Aalto and using it more and more, which makes me wonder what kind of hardware with lots of knobs could I use to get the kind of chaotic sounds Aalto is capable of ? Having lost my MS20 and being a big fan of the metallic wild s**t it does, I've started making patches with Aalto that have the HP/LP and feedback that I'd bring from the 20, but then I can take it even farther and get wild digital sounds. Having also owned the MEK (though I didn't get as familiar with it as I wish I had since I was doing more basic soft leads / bass sounds), I'm kind of thinking that is quite similar in structure... 2 digital oscillators and 2 analog oscillators; lots and lots of weird routing possibilities etc. So... would that be the closest to kind of having a hardware Aalto or is there something else I'm missing ?? I'd really like to use a piece of hardware when I play out, but I'd also like to get similar sounds.
- meatballfulton
- Gear: Logic Pro X
Re: Closest Hardware Synth to Aalto... or Aalto vs. Mek
Well, Aalto is based on a Buchla complex osc and low pass gate plus a delay/waveguide and an SEM filter. So I guess some sort of Buchla plus an SEM reissue? Start saving your pennies! This is one example where softsynths can be worthwhile
As far as MEK...the FM capabilities aren't as good as what Aalto offers, more aliasing for sure. The digital HPF is non resonant which is another limitation. No low pass gate either. Similar territory I suppose but owning an Evo desktop and Aalto I don't find them that similar in sound...then again I haven't tried to dial up the same sound on both so what do I know
- Real name: Zayne
Ahh Buchla... An often overlooked company. You raise some very good points which I neglected on the MEK. I didn't realize the High pass is a digital filter... And you're right about aliasing. Damn... This is reminding me how much I wanted to start a modular last yearmeatballfulton wrote:Well, Aalto is based on a Buchla complex osc and low pass gate plus a delay/waveguide and an SEM filter. So I guess some sort of Buchla plus an SEM reissue? Start saving your pennies! This is one example where softsynths can be worthwhile![]()
- Stab Frenzy
Sounds like you want a Music Easel.
- Real name: Zayne
Stab Frenzy wrote:Sounds like you want a Music Easel.
Ooh a worthy goal far in sight.
- meatballfulton
- Gear: Logic Pro X
Hey, what's another $4000 between friends?
- Stab Frenzy
Street price is $3600.
