Atari 520 with cubase...click problem
princefan3
Post by princefan3 » Fri Nov 07, 2014 8:58 pm
Hi again...having trouble with the metronome click not sounding correctly...it's intermittent and it's bloody frustrating...what could this be....everything is ticked....just can't seem to work it out....any ideas
Re: Atari 520 with cubase...click problem
Post by madtheory » Fri Nov 07, 2014 9:31 pm
Cubase 3.0?
princefan3
Post by princefan3 » Fri Nov 07, 2014 10:00 pm
No even earlier 2.0....he he
max badwan
Real name: Max
Post by max badwan » Fri Nov 07, 2014 10:25 pm
are you using MIDI click or the internal beep click?
princefan3
Post by princefan3 » Fri Nov 07, 2014 11:41 pm
I'm trying to get the Atari to produce the click it used to....the internal bleep click
max badwan
Real name: Max
Post by max badwan » Sat Nov 08, 2014 12:19 am
princefan3 wrote:I'm trying to get the Atari to produce the click it used to....the internal bleep click
My guess would be that the internal sound chip has developed a fault, but that's only a guess. You can still use the MIDI click, though.
Post by madtheory » Sat Nov 08, 2014 12:23 am
3.0 is much better, I used 2.0 only briefly. My guess is crack don't work proper...
max badwan
Real name: Max
Post by max badwan » Sat Nov 08, 2014 12:57 am
madtheory wrote:3.0 is much better, I used 2.0 only briefly. My guess is crack don't work proper...
I agree, I've got 3 Score - and it's not much different from SX in look/feel. And I've got the dongle. :lol:
gcoudert
Real name: Gilles
Post by gcoudert » Sat Nov 08, 2014 9:54 am
Assuming your click goes through your monitor speaker (as mine did when I used Cubase on my Atari 1040STF), could there be a loose connection in the monitor's internal audio path? It is nice to see that some musicians still use Ataris. I have fond memories of working with the MIDI-only Cubase and, before that, Dr T.'s MRS on the Amiga 500.
GC
