MICROBRUTE update frozen! SOLVED
ravenmek
Post by ravenmek » Tue Nov 11, 2014 6:01 am
I tried to update my new microbrute to the newest firmware, but it froze on 0%. Now my microbrute doesn't work, and I can't find the "tech support" document all the forums talk about... Any ideas?
loungedumore
Gear:iMac | iPad 2| iPad Air
Beatstep Pro | Mpx8
Volca bass, Keys ,beats
Monotribe | MS20 | SQ1
Minibrute | Midi4+
Graphite 49 | EIE
Band:Death By Media
Re: MICROBRUTE update frozen!
Post by loungedumore » Tue Nov 11, 2014 5:07 pm
It's in the connection PDF under trouble shooting .....
" 4.4.2 Update has been interrupted
If something went wrong during the firmware update process (computer crash, unplugged USB cable, zombie attack, etc.), there is still a possibility to restore the instrument:
1. Close the MiniBrute Connection software.
2. Reboot the instrument while pressing down the octave Down and Up buttons: all octave LEDs should be lit.
3. Launch the MiniBrute Connection software: you will be prompted for the automatic firmware update. Just cancel, it won't work.
4. Enter into the Firmware Update view, and run the manual update.
5. Reboot the instrument, then click OK. Your MiniBrute is now fully restored and updated. "
I had to do it more than once before . Also I can't remember but I may of had an issue using a USB hub so if you are you might try direct from computer .
Also this should be in the help section btw
ravenmek
Post by ravenmek » Wed Nov 12, 2014 12:04 am
Loungedumore, I'm sorry about the forum mistake, it was really late here and I wasn't really paying attention, just desperate to make it work!
I don't have that pdf, as it isn't in the zip that has the microbrute connection (it's not there anymore!).
The method you described was half the solution! As I have windows 8.1, it won't work directly, so I had to start compatibility mode for win 8. That way, it started to work again.
Thanks a lot for the data!
