Korg Triton Disk Format
mustang1956
Post by mustang1956 » Thu Dec 18, 2014 5:27 am
I just got a Korg Triton Pro X and the disk will not format the floppy. It did format my SCSI Hard Drive. I'm thinking there is an issue with the software. (Of course I need to format the floppy to create a new factory preload or update the OS). Does that sound reasonable? (Sorry this is probably a dumb question but I am a rookie!!)
Re: Korg Triton Disk Format
Post by meatballfulton » Thu Dec 18, 2014 1:17 pm
Sounds like the drive is toast. The Triton can use bioth DD and HD floppies so it shouldn't be a floppy type issue.
Try formatting on your computer (hope you own a floppy drive!) as MS-DOS and see if the Triton can read it.
Good luck.
mustang1956
Post by mustang1956 » Wed Dec 31, 2014 10:51 pm
Thanks for the suggestion. I was able to format the disk on my PC and the disk was able to read the contents.
