SH-101 Gate stuck open
soniccustard
Post by soniccustard » Sun Mar 15, 2015 1:59 pm
Hey, been visiting the site for a while, first time posting, but now I need some help!
I have an SH-101 that needs fixing and it seems like the gate is constantly open, it will never stop making a sound until you pull the sustain part of the envelope down. I'm sure this can't be normal activity for a 101? It works perfectly via external CV control, it seems to be just to do with the internal gate.
Can anyone help at all? I keep prodding around it but I just can't find the source of the problem. I've got the service notes with have a lot of block diagrams and schematics for it which are kind of helpful but I still can't identify the problem.
Thanks!
HideawayStudio
Real name: Dani Wilson
Band: Shortwave
Re: SH-101 Gate stuck open
Post by HideawayStudio » Sun Mar 15, 2015 3:19 pm
soniccustard wrote:Hey, been visiting the site for a while, first time posting, but now I need some help!
Thanks!
Hi,
Does the sound stop if you plug a jack into the gate input? (with nothing connected at the other end of the lead).
soniccustard
Post by soniccustard » Sun Mar 15, 2015 3:20 pm
Yeah it does, the Envelope works via the LFO, too.
Edit - I've actually disconnected everything now, the buttons, the keyboard and most of the bender board, it's still going.
HideawayStudio
Band: Shortwave
Post by HideawayStudio » Sun Mar 15, 2015 3:28 pm
soniccustard wrote:Yeah it does, the Envelope works via the LFO, too.
Is the Hold LED lit?
soniccustard
Post by soniccustard » Sun Mar 15, 2015 3:34 pm
No, the button seems to work as well, when you press it the light comes on and off and the arpeggiator hold function works accordingly.
HideawayStudio
Band: Shortwave
Post by HideawayStudio » Sun Mar 15, 2015 3:50 pm
soniccustard wrote:No, the button seems to work as well, when you press it the light comes on and off and the arpeggiator hold function works accordingly.
So you are definitely saying that if you insert a jack into the gate input the sound stops?
If so then it is possible TR9 has failed or there is a dry joint. It would be worth checking, if you have a scope or logic gate, whether the voltage to the 100K standoff resistor (R49) feeding its base is seeing a state change during key on/off - if not then you might have a cracked track or dry joint anywhere from pin 38 on the CPU to TR9.
soniccustard
Post by soniccustard » Sun Mar 15, 2015 3:53 pm
Yes, an inserted jack kills the sound. I'll have a look at TR9, I thought from looking at the schematic that TR29 might be the issue, but then I've never opened a 101 before!
Thanks for the tip, I'll give it a look right now.
HideawayStudio
Band: Shortwave
Post by HideawayStudio » Sun Mar 15, 2015 3:57 pm
soniccustard wrote:Yes, an inserted jack kills the sound. I'll have a look at TR9, I thought from looking at the schematic that TR29 might be the issue, but then I've never opened a 101 before!
This is why I got you to try plugging in a jack into the gate input - by doing this it determined whether the gate receiving circuit (TR29) was stuck or the gate generating circuit (TR9) was stuck as the gate input is normalised on the SH-101 thus disconnecting the internal gate generator.
In your case its the gate generator (TR9) that is stuck which is driven directly by the CPU.
