Any synth with a multitimbral arp section?
Hi!!
I want 5 different ARPs to play simultaneously in one tempo, with 5 different sounds(for example)/ Is there any synth that could make such a trick?
- vicd
- Real name:Victor
- Gear:Blofeld, Formanta (EMS01, Maestro, Mini), Fusion 8HD, JD800, Morpheus, MP7, Plugiator, TG77, TOM1501, TR626, UltraProteus, V-Synth XT
- Band:ROBOPOP
Re: Any synth with a multitimbral ARP section?
Anything from E-mu's p2K range will do.
http://www.vintagesynth.com/emu/xl7.php for instance.
I don't like the drums, but the drums like me!
- Z
- Gear:Bubble wrap, Styrofoam, boxes, packing tape
Please don't capitalize the abbreviation to arpeggiator like that.
But to answer your question, I'm pretty sure the Roland Fantom X series can do that.
- Purveyor
- Band:Purveyor
Novation's KS series does 4 simultaneously very easily (including separate effects per part).
Thanx, can I use different patterns simultaneously?And can they be transmitted via the midi to some external devices?vicd wrote:Anything from E-mu's p2K range will do.
gcoudert
- Expert Member
- Real name:Gilles
- Gear:Roland Fantom X7 with Ultimate Keys expansion, Yamaha TX802, Roland JP-8080, Tascam DP-24SD.
No, I don't think so. In Performance mode, you can specify which one of the 16 Parts is affected by the single arpeggio pattern running but that's it.Z wrote:I'm pretty sure the Roland Fantom X series can do that.
GC
- vicd
- Real name:Victor
- Band:ROBOPOP
Yes and yes. See e.g. p.28 of the MP7 manual for an example of a multichannel arp.philip wrote:Thanx, can I use different patterns simultaneously?And can they be transmitted via the midi to some external devices?vicd wrote:Anything from E-mu's p2K range will do.
Arp/riff MIDI output is switchable since firmware update 2.0 - options are: don’t transmit, transmit arps, transmit riff, or transmit both.
- V301H
- Gear:Fender The Strat, Stratocaster, Jazz Bass Rickenbacker 360-12, 320 Messenger(Mark Farner)
- Band:The Characters
Re: Any synth with a multitimbral arp section?
i'm pretty sure a Casio with Hex-layers such as the XW-P1 or PX-5S could do six arpeggios at one time with different sounds.
- ninja6485
- Gear:Virus Ti, Jx-8p, Juno 60, Radias, Maschine, 101,303,606,707,727,808,909, odyssey, mirage, akai s5K/s2K/s1k, drumtraks, E6400ult, M1R, rx5, fizmo,d50
- Band:Subliminal Sea
You should be able to use the arpeggiator on all 16 voices of the virus TI
- meatballfulton
- Gear:Logic Pro X
Ableton Live
Nektar Panorama P6
Launchpad X
MOTU M2 interface
Yamaha Motif XS and XF can run 4 arpeggiators at once when in Performance mode. Only one of the four can send over MIDI, the other three cannot since they share the same MIDI channel. Each arpeggiator can select between up to 5 patterns in real time. A quick record mode allows recording from Performance mode directly into a sequence.
- Zamise
- Gear:Rollhand P00
- Band:Quantum-Source
I was just reading the new Montage can do 8 simultaneous Arps and are assignable to parts + + and + pg 24 in manual. It is an arpiggating beast. I want one pretty bad, but still new and too pricey for me.
"The Audity 2000 is a digital synth with an unprecedented 16 simultaneous arpeggiators"
http://www.vintagesynth.com/emu/audity2000.php
- cornutt
- Gear:6th
The V-Synth might be able to do it; I'll have to try it. But that knowledge isn't very useful since the V-Synth in general doesn't do multitimbrality very well.
The Virus kb/b can have arpeggiators running on all 16 parts simultaneously. And every model after that can do it too.
For posterity...The PX-5S can play four different arpeggios, each playing a different tone if desired. The XW-P1 can play only one arpeggio at a time (with up to four layered tones).V301H wrote:i'm pretty sure a Casio with Hex-layers such as the XW-P1 or PX-5S could do six arpeggios at one time with different sounds.
