I'm working on a beat up old CP70. It's been really fun! I'll post some pictures when I'm done with the new finish, it's something quite different!
The previous owner had done the passive mod, because the preamp/power supply was malfunctioning.
I'm trying the figure out how to get it working again. I've found a replacement 18v power adapter and soldered on the 2 pin XLR connector and it's works great. The voltages ranges from 16 - 20v DC, it's was easy enough to find one.
So far so good.
Yesterday I measured power voltages from the source voltage pre amplifier board, that is between the adapter and the actual FET preamp with the eq and tremolo fx.
The voltages should be 8v, 12v and 16v. The 12v line was 8,5v. Therefore i went to my electronics store today and bought some new electrolytic capacitors and replaced the old ones, 3x220uf 25v and one 470uf 25v. The old ones looked fine btw, but I've heard many times that that is a good thing to due to 40+ year old gear, and thought that was were the trouble was.
The voltages are unfortunately the same still.
8v line (for the tremolo circuit) =8v fine
12v line (for the preamp circuit)= 8,5v bad
16v line (for the tremolo circuit)=15,9v fine.
I'm trying still to identify the problem, and I'm having a hard time figuring out if it's the 2 semiconductors, a transistor and a low level voltage regulators that is causing the trouble. Look at the pictures and help me identifying them if you can.
Let me know your ideas.
Upon testing the unit, noise passes through the active outs, tremolo works, as I can here it changing the noise when i turn the volume up and turn the rate/depth knobs.
The 12v line for the preamp however (of course) is malfunctioning, because it only gets 8.5v from the source voltage pre amplifier board, and not 12v like it should.
Here are a couple of pictures.
By the way, the piano worked fine with the passive mod, but I'm interested in restoring it back to working condition with eq, tremolo and linelevel outs, as I dont want the play it though a guitar amp all the time. I'm not either interested in 3rd party DI's or mic preamps to buff up the signal.
the best greetings from Peter
