Roland Expansion Card Patches & JV 880
kspssd
Post by kspssd » Sun Sep 29, 2013 11:30 pm
Just found this website in a mad search for info...
I recently purchased the SR JV 80 -98 Experience II board for my JV 880..
For the life of me I cannot access the Patches. I have read my manual and tried the "Load Patch Single and Load Patch Group" but... I get a "Parameter Not Exist" message.
ANY help would be appreciated.
Thanks
max badwan
Real name:Max
Gear:T1, XV 5080, ES1, Zaquencer
Re: Roland Expansion Card Patches & JV 880
Post by max badwan » Sun Feb 23, 2014 11:17 pm
Is the board seated correctly? Open her up and check to make sure, as it's the only thing I can think of that might help - although the OS might not recognise that high a number (i.e. SR-JV80 ##) board - when the 8/80 was released there was only a couple avalable, so the OS might not be able to see that high a number board. Hope that helps.
Mr_Mojo_Risin
Gear:MKS-70, JX-10, MKS-50, U-20, S-50, S-550, W-30, JV-880, GR-1, U-110, D-110, FB-01, Kawai K1r, PGH 10+1 x 2, ME20A, ME30P, LM-3204
Band:Factorial
Post by Mr_Mojo_Risin » Wed Sep 28, 2016 2:54 am
The JV-880 and other models are unable to use any of the Patches on this board. You can only use the Waveforms. The SR-JV80-98 Experience II board is kind of a kludge. It does not work like the other boards in the SR-JV-80 series.
Taken from the SR-JV80-98 Experience II user manual;
"This 'tryout' expansion board features unique specifications which make it incompatible with the JD-990. The JV-80/880/90/1000 allows you to use only waveforms."
