Korg POLY 800 strange problem
mono
Post by mono » Fri Jan 24, 2020 3:58 pm
Hello friends!
I would like to ask if someone had this problem with POLY800.
It turns on. Eferything works good. After 2 minutes of play it starts to play random keys very fast for some time and stops. when i start to play again it again generates random keys. After several tries all sounds resets to noise. I can upload factory sounds from tape and again everything goes the same as before.
thanks
D
Tyco72
Re: Korg POLY 800 strange problem
Post by Tyco72 » Tue Jan 28, 2020 12:17 pm
It could be a dirty signal path, due to dried electrolytic capacitors, or dirty DC voltage. As first you can try with another power supply (it should be extern, if I remember correctly). If it doesn't help, it could be some bad capacitor inside. In aged electronic boards, the first things to check/replace are the electrolytic capacitors.
oryjen
Post by oryjen » Wed Jan 29, 2020 9:56 am
Check the memory storage battery.
Good luck for opening that plastic horror.
Korg MS10-MS20-MS50-SQ10-X911-SuperDelta-800DV-MP4-ES50-P800-PE1000-M500SP-Trident MkII-KPR77-DSS1-P61-Volcas&Monotrons/Eko P15/YAMAHA CS30-CP30-DX9/RSF Bbox x2/Viscount CL1-R64/SCI Multitrack-P600/Roland GR500-SH1000/TimbreWolf/SX210/Mx3000
Tyco72
Post by Tyco72 » Wed Jan 29, 2020 11:14 pm
Yes right, it can be more likely the battery in this case, if all the sounds ghe reset to noise.
