Juno 106 not receiving Sysex
bt63
Post by bt63 » Wed Mar 30, 2022 4:43 pm
So my Juno 106 is not receiving Sysex data it seems. I have a Juno 106 plugin to control loaded in Ableton with the output to the midi cable connected to the Juno, and the switch on III. Everytime I switch a parameter and send the settings the Juno does nothing. Ive been able to in a certain iteration change the patch, but no luck changing actual parameters. It's an earlier Juno(march 1984) could that be a potential problem?
Mesmerised
Real name:Chris
Gear:Minimoog, ELKA Rhapsody, MFOS Modular, TTSH, Matrix 1000(2x), K5000S, MI Ambika(2x), Shruthi (3x) and Anushri, Sonic Potions LXR, JX-8P, D-50,...
Band:Palantir
Re: Juno 106 not receiving Sysex
Post by Mesmerised » Thu Mar 31, 2022 1:23 pm
If the switch is set to III it should be working! You can change patches and trigger notes? Then MIDI is generally working. Maybe the Midi mode switch is a bit rusty... Maybe try a different editor software?
Real name:Tomas Mulcahy
Post by madtheory » Thu Mar 31, 2022 1:58 pm
Need more information. Ableton will only transmit SysEx via Max for Live. Do you have that? What is the plugin?
bt63
Post by bt63 » Thu Mar 31, 2022 7:35 pm
Mesmerised wrote: ↑
the midi does work I can trigger and have it play midi from Ableton.
madtheory wrote: ↑
I've been using this plugin which makes Ableton able to transmit patch and slider information via sysex, or thats what I'm under the impression it does. I have had some luck changing the presets using one of iterations of this plugin, but thats it. No slider info gets transmitted when I change it in the plugin.
https://maxforlive.com/library/device/2 ... d-juno-106
Post by madtheory » Thu Mar 31, 2022 11:25 pm
Just checking- have you read the comments under that post? There have been two updates since it was first posted. And no confirmation that the most recent one (2016) is still functional.
bt63
Post by bt63 » Fri Apr 01, 2022 12:38 am
madtheory wrote: ↑
Good call, Ive seen a more recent one, but this is from 2018. Ableton 11 does support sysex, but I probably have to make my own device or find another
thanks
Post by madtheory » Fri Apr 01, 2022 9:25 am
To be clear, only Live 11 Suite supports SysEx. Live 11 Standard does not. But I assume this plugin would not even launch without Max anyway!
Pretty cool plugin. If it was me, I'd sell the Juno and look at a modern analogue such as Novation Peak, or even a Prophet or Waldorf. The Juno sounds great but is so limited IMHO. But that's just me :)
bt63
Post by bt63 » Fri Apr 01, 2022 8:56 pm
Yea I have the suite version, and max. It's weird that I can change patches with it but not sliders.
sacrilege haha, I love my Juno so much probably will never get rid of it. Its not really conditional having these functions it would just be nice.
Post by madtheory » Sat Apr 02, 2022 5:21 pm
I hear ya :D
