replacing a korg poly 800 battery
Post by *** » Mon Jun 14, 2010 7:08 pm
I keep losing all my presets when i switch of my korg so i opened it up to try and replace the battery but it turns out the battery doesn't exist. it's a mark 1 korg so it doesnt look like this one
http://www.pallium.com/bryan/polybattery.php
any advice?
rhino
Real name:bill
Gear:keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: replacing a korg poly 800 battery
Post by rhino » Mon Jun 14, 2010 10:43 pm
IIRC, the MkI used the same batteries that make the synth play to save memory as well.
Uses 6 "C"-cells
- Confucius
Gear:Logic Pro X
Ableton Live
Nektar Panorama P6
Launchpad X
MOTU M2 interface
Post by meatballfulton » Mon Jun 14, 2010 11:33 pm
Some MkI P800s do have the space on the motherboard for the backup battery but it wasn't installed at the factory. Easy to add if you know how to solder.
In the meantime, get some C cells. If you don't use them to actually power the synth they will keep the memory alive for a couple of years.
Hybrid88
Gear:V-Synth, and other stuff...
Post by Hybrid88 » Thu Jun 17, 2010 5:15 pm
Instructions for the battery mod - do so at your own risk.
http://analog.no/cms/index.php?option=c ... &Itemid=49
JHatzia
Post by JHatzia » Tue Jan 10, 2017 7:14 pm
I have a Korg Poly 800 mk1 without the square solder lands for a back up battery. Do any mods exist for this version or am I doomed to always use C-cell batteries for saving all my patches while the unit is off?
ewasawe
Post by ewasawe » Mon May 02, 2022 7:02 pm
Hello, the guide that @Hybrid88 seems not working. Maybe someone deleted it.
Could i have an active link to the guide, or a video that shows how to do it?
I am in the same situation.. no presets, And no battery place on the motherboard of the korg poly 800 .
