I keep losing all my presets when i switch of my korg so i opened it up to try and replace the battery but it turns out the battery doesn't exist. it's a mark 1 korg so it doesnt look like this one
http://www.pallium.com/bryan/polybattery.php
any advice?
replacing a korg poly 800 battery
- rhino
- Real name:bill
- Gear:keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo - Location:kentucky hills
Re: replacing a korg poly 800 battery
IIRC, the MkI used the same batteries that make the synth play to save memory as well.
Uses 6 "C"-cells
Uses 6 "C"-cells
- Confucius
- Confucius
- meatballfulton
- Moderator
- Gear:Logic Pro X
Ableton Live
Nektar Panorama P6
Launchpad X
MOTU M2 interface
Some MkI P800s do have the space on the motherboard for the backup battery but it wasn't installed at the factory. Easy to add if you know how to solder.
In the meantime, get some C cells. If you don't use them to actually power the synth they will keep the memory alive for a couple of years.
- Hybrid88
- Gear:V-Synth, and other stuff...
Instructions for the battery mod - do so at your own risk.
http://analog.no/cms/index.php?option=c ... &Itemid=49
I have a Korg Poly 800 mk1 without the square solder lands for a back up battery. Do any mods exist for this version or am I doomed to always use C-cell batteries for saving all my patches while the unit is off?
Hello, the guide that @Hybrid88 seems not working. Maybe someone deleted it.
Could i have an active link to the guide, or a video that shows how to do it?
I am in the same situation.. no presets, And no battery place on the motherboard of the korg poly 800 .
