MS-20, volume signal very low, what can I do?
I've have recently purchased a MS-20 and the first thing i've noticed is how quiet the signal is compared to my newer synths. I've also noticed that if I use the headphone output instead of the signal output it is slightly louder.
Is there any way of getting a louder signal on the MS-20 before it goes through your desk, what do most peole do to boost the signal?
Some sort of pre amp perhaps?
- Maschinengeist
- Real name:Steph. J
- Gear:Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff - Band:Cybernetik
Usually, a weak signal indicates a problem with either the VCO, LFO, VCF or VCA.
In this case, since the Headphone output seems ok, then I'd check the resistance values in the path circuitry. And while at it, check the filter cap too. Maybe the HPF/LPF Cutoff Frequency needs to be adjusted.
Last edited by Maschinengeist on Sun Oct 22, 2006 7:14 pm, edited 1 time in total.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
MuzikElektronix.com
Help? See TechZone
Parts? email!
- Anaki_Muon
I've never had problems with my MS20 when the patchbay isn't being used, and the volume level is perfectly fine. I'd be inclined to say Maschinengeist is probably on to something here, but you may want to have a synth technician take a look at instead of messing with it yourself (unless, of course, you're comfortable with that).
Korg MS20 & Wavestation A/D, Roland Juno 60 & Juno 106 & MKS50 & D110 & MC202, Ensoniq EPS, Yamaha FB01, SP07b, Casio CZ5000 & SK1, Alesis Micron, Cakewalk Z3ta+, Propellerhead Reason, Garriton Personal Orchestra
- Maschinengeist
- Gear:Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
Yeah, you're right and neglect to mention it. If you're not at ease with such a task (no shame... it's getting technical and who wants to wreck such a fine piece of technology?), it'd be wise to seek the synth doctor of your area.Anaki_Muon wrote:I've never had problems with my MS20 when the patchbay isn't being used, and the volume level is perfectly fine. I'd be inclined to say Maschinengeist is probably on to something here, but you may want to have a synth technician take a look at instead of messing with it yourself (unless, of course, you're comfortable with that).
MuzikElektronix.com
Help? See TechZone
Parts? email!
MuzikElektronix.com
Help? See TechZone
Parts? email!
- Anaki_Muon
Heh heh, yeah... wait- what? What an odd thing to say. I like your new avatar by the way, Maschinengeist.Maschinengeist wrote:Yeah, you're right and neglect to mention it.
If you have no electronic knowledge it's best not to fiddle with a synth.
Anyway the ms patchbays do cause problems if not used or if there has been a jack inserted for some time.
I have seen these problems on mine and others.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
- Maschinengeist
- Gear:Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
So I see that you appreciate my brand new Typo Master 2000!Anaki_Muon wrote:Heh heh, yeah... wait- what? What an odd thing to say. I like your new avatar by the way, Maschinengeist.Maschinengeist wrote:Yeah, you're right and neglect to mention it.
MuzikElektronix.com
Help? See TechZone
Parts? email!
MuzikElektronix.com
Help? See TechZone
Parts? email!
Thanks guys,
The volume is fine for most sounds IE loud Bass, Leads etc. So i'm not sure its a problem with the unit.
Basically i've made a particular 'squelchy' sound that I want to use in a track, its this sound that seems to be very quiet. If I change the sound (IE by moiving the cutoff etc) the sound becomes louder but different and not how I intend to use the original sound.
So I was wondering if there is a good way of amplifying certain sounds that appear to be quieter than others.
- Spike Vincent
- Location:People's Republic of The Forest of Dean,and why isn't there a Welsh flag option?Eh?
- Anaki_Muon
Wait a second... are you talking about raising both the peaks and cutoff frequency for the high-pass and low-pass filters? I've noticed doing so can cause the volume to 'sound' quieter, but I say that's normal when you start to isolate only high frequencies like that. Can you be more specific about the actual knobs your twisting here?
