I picked up a TR-606 off eBay the other day and have noticed that it is outputting a very high pitched tone. Sometimes this tone is a little louder when I connect other CV gear to it.
Does anyone have any experience with this and know how I might be able to repair it? Thanks.
CV noise from analog synths.
- nathanscribe
- VSE Review Contributor
Be really careful with that, the 606 draws very little current and using a high rated PSU (say 500 mA) may result in a high voltage issue since most transformers get a little squirrelly when your only sucking ~100 mA through them. The orginal boss one is a 200 mA max. Using a unsuitable PSU is a common failure mode for the power transistor on both the 606 and 303 since pumping more than 9 V through it degrades it pretty quicklyi don't have the original and have been using one of those radio shack adapters
- nathanscribe
As long as your power supply is regulated it should provide a constant, fixed voltage even with a relatively low current draw. But yes, you won't want a 1.5A wart or anything like that.. Just get a regulated 300mA 9V supply from any manufacturer, you don't need an original Roland one. I use a bunch of those switchable ones with the interchangeable plugs. Pity they don't sit next to each other on the distribution board though, slightly too wide. Grr!Altitude wrote:Be really careful with that, the 606 draws very little current and using a high rated PSU (say 500 mA) may result in a high voltage issue since most transformers get a little squirrelly when your only sucking ~100 mA through them. The orginal boss one is a 200 mA max. Using a unsuitable PSU is a common failure mode for the power transistor on both the 606 and 303 since pumping more than 9 V through it degrades it pretty quickly
This is true, however most cheapo wall warts are not regulated an they rarely say if they are.As long as your power supply is regulated it should provide a constant, fixed voltage even with a relatively low current draw.
Here's a site about the issue:
http://www.firstpr.com.au/rwi/dfish/rel ... l#adaptors
