Hello guys, i've a battery saved polysix, now perfect working except a stupid problem:
Every time i set a Patch, i have the Modulation ON, and if i want to stop it, everytime i need to set the frequency pot to zero. Also with the pot to zero, if a change patch, modulation again ON.
Is normal wich every Patch on the Polysix have the modulation ON? or is a problem of mine...
thanks!
Polysix and Modulation ever On
- rhino
- Real name:bill
- Gear:keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo - Location:kentucky hills
Re: Polysix and Modulation ever On
hello. let's see if we can help you.
questions:
1. does the MG 'mod' switch correctly send the LFO to the ocs, filter, vca?
2. what does the MG 'depth' knob do?
3. any change when you move the mod wheel?
4. if you hold a note, does the MG change after time?
questions:
- Confucius
- Confucius
Dumb question, but have you tried specifically to save a patch where the lfo level is all the way off? It may be that the patches have all written themselves when you changed the battery, but once you start saving, it should save whatever you panel values are.
Do you even post on vse bro?
- rhino
- Real name:bill
- Gear:keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
good catch. sometimes i am impervious to the obvious.
have i missed this too? where is the 'spell-checker' for posting?
- Confucius
- Confucius
ok guys!
i've made the test of saving a patch with the mod disabled and.......... mmm.......
no more modulation!
it's all ok, but the factory patch have a lot of modulation everywhere
thanks thanks to all!
no more modulation!
- rhino
- Real name:bill
- Gear:keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
glad you had success!
Korg DW-6000 and 8000 seem to come back from battery change with loooonnnnng slow filter envs, and long release vcf envs.
go here to reload factory patches:
http://virtual-music.at/webseiten_e/zubehoer/korg.htm
- Confucius
- Confucius
- iProg
- Expert Member
- Real name:Carl
- Gear:Prophet-5, Korg PolySix, Roland D-50, JV-1080
- Band:ArtWithHeart
Haha! Great! Enjoy the P6 - a part of vintage history!tasters wrote:ok guys!
no more modulation!
iProg wrote:Haha! Great! Enjoy the P6 - a part of vintage history!tasters wrote:ok guys!
no more modulation!
Yess, in these days i'm triyng it with a Jupiter 6, really different beasts, but the p6 is the more versatile and simply and direct
