Hi there,
i got across with a bug in the NI reaktor 5 on MAC leopard with Ableton Live 7.
When any pop up message comes up i cannot get further. The program doesnt answer at any command and seems to be freezed. Then I can only force the quit and reboot up everything. I tried to uninstall the reaktor from the database and reinstall it, using even different installers, but no way, the problem is still there.
Anybody knows if there is a reaktor uninstaller?, delete manually the directories of reaktor is quite tricky and probably a proper deinstalling process would solve the solution.
Thanks to everybody.
ciao.
NI Reaktor 5 BUG
gekichan : : : : Clavia Nord Modular; Elektron Machinedrum; Studio Electronics XTC-1 Chamaleon; DSI Polyevolver, Roland TR707.
- mono/noise
- Junior Member
Re: NI Reaktor 5 BUG
Reaktor 5 has been buggy for me also in Live 7, I haven´t encountered the problem you are talking about but Live regularly crashes on me when I'm using Reaktor. It seems to be a Live related problem because it's rock solid in Logic.
www.myspace.com/mnoise
Gadgets: Pulse+_Opera 6_Jen SX1000_microKorg
Xbase 09_SK-5_CZ-3000_ESQ-1_Electone A-55_Theremin
Cracklebox_Thingamagoop_Game Boy( LSDJ )_KP3_MPD24
Tascam Porta 07_Multimix 12_Logic Studio_Live 6
blitzdj86
- Junior Member
- Gear:Modified DR-110, ES-1 Mk2, KP3, Various Pedals, MG82CX mixer.
I had this problem, it's not to do with live - it happens when reaktor is running on its own too.
I just assumed the err "trial" version of reaktor I was using was some dodgy hack.
Are you using a legitimate reaktor 5?
- meatballfulton
- Moderator
- Gear:Logic Pro X
Ableton Live
Nektar Panorama P6
Launchpad X
MOTU M2 interface
Macs don't require uninstallers, you can just delete the files.
There are programs like Spring Cleaning that can automate the process.
- mono/noise
- Junior Member
Well it has to do with Live in my case because it's not happening in standalone mode or when loaded into Logic. And yes I'm using a up to date legal version of Reaktor, I'm starting to think it has something to do with user made ensembles because it's seems to work ok with the stock stuff.blitzdj86 wrote:I had this problem, it's not to do with live - it happens when reaktor is running on its own too.
did you try to get in touch with the NI custumer support?
I cannot given the unlegitimate version of my reaktor.
they might have an answer to this problem.
- mono/noise
- Junior Member
Not yet no, but from what I have heard they aren't the most responsive company out there. Also this problem only recently popped up for me because usually I use Live strictly for audio and Logic for the midi stuff.gekichan wrote:did you try to get in touch with the NI custumer support?
bluedad
- Junior Member
- Gear:Yamaha Motif ES rack/DX7//TG77/SY77/AN1X/MM08 MicrowaveXT/ Korg DW8000/M3r/ Ensoniq ESQ-1 /Mirage Rack/ Nord Micro DSI Mopho Roland Juno 106/D550
- Band:Split Second
why not post something at the NI forums?mono/noise wrote:Not yet no, but from what I have heard they aren't the most responsive company out there. Also this problem only recently popped up for me because usually I use Live strictly for audio and Logic for the midi stuff.gekichan wrote:did you try to get in touch with the NI custumer support?
@gekichan - shame on you!
