Help with Duran Duran's "Rio"
Ncapone
- Gear:Roland V-Synth
Moog Sub 37
Korg EMX-1
Crumar Performer
Dave Smith Instruments Prophet 08 - Band:Terrapin
Hi , I'm trying to put together some sequencer backing tracks to this song, but I am really stumped on that swirly space y sound during the bridge. I have no idea where to start. Any help would be appreciated. Thanks!!
- fh991586
- Senior Member
- Real name:Francis
- Gear:Korg Kaossilator, MicroKorg,
Midines - Location:French Canada
Re: Help with Duran Duran's "Rio"
Have you studied this track?
Available for sale:
-Chamber of Sounds Jupiter III (mk1) & Jupiter T (mk1)
Ncapone
Moog Sub 37
Korg EMX-1
Crumar Performer
Yes, but I just have no idea where to begin. If that sax wasn't there it would be easier.
- fh991586
- Senior Member
- Real name:Francis
There is at least 10 seconds before the sax comes in (around 2:36 to 2:47), so it should be enough to figure out what's there. Unless you're searching for something else?
Available for sale:
Ncapone
Moog Sub 37
Korg EMX-1
Crumar Performer
No, that's the part I'm looking for. But I am so lost tht I don't even know where to begin with it. Is it a multiple track? Something I hadn't even thought of?
- fh991586
- Senior Member
- Real name:Francis
Yes, this track still has multiple layers, which none is available as stand alone: it's pretty lucky that this song (and some others) are on YT with separate layers, although not to every single tracks.
The portion you want shows at least 3 subparts: the clap sequence, a pad and the spacey thing. I don't know how to create any of the 2 synths sounds that are merged in the "space pad" mix, so you're pretty much on your own there... First, you shuold learn about the kind of synths used by Nick Rhodes at the time (most likely both Jupiter 4 & 8 on this precise part), and then see if your own synths can recreate a similar sound. What's your gear?
Available for sale:
Ncapone
Moog Sub 37
Korg EMX-1
Crumar Performer
I only have some soft synths-- all of those that are packaged with Logic Pro, all of the arturia classic synths, and some other plug ins as well. I'm sure one of those will get the right sound. I was thinking it might have been the prophet 5. The spacey wail is the specific sound I'm after.
- fh991586
- Senior Member
- Real name:Francis
I can't help you with those soft synths... But maybe there is some effect added to the sound?
On second thought, I do feel like there is a ressemblance with the intro from "Night Boat". Maybe it's a reprocessed excerpt?
Good luck with your project!
Available for sale:
Fatbenelton
- Gear:ModelD, Odyssey, Analog Keys, EX8000, D550, Nord 2X, KR55, MP7, TX816, Tenori-On, Kawai K5000S, Dr110&220, Argon8
Years later I know but in the interests of anybody with a similar question doing some research.....
The spacey sound is a Jupiter 4 preset 'voice' layered with a synth string pad. As somebody mentioned it is indeed also used via a slow arp on the beginning of 'Nightboat'.
Jonny Jones
- fh991586
- Senior Member
- Real name:Francis
Weird to read some of my old contributions!
The strings layer must have been from a Crumar Performer then...
Available for sale:
