Hi,
there is a guy selling a Polyevolver with the encoders problems.
What is the problem and how can it be fixed?
Thank you in advance.
DSI Polyevolver encoders problem
- Stab Frenzy
- Moderator
- Gear:Eurorack, RYTM, Ultranova, many FX
Re: DSI Polyevolver encoders problem
The problem is that they go forward when they're supposed to be going backward, skip values, move slowly. It's pretty annoying. You can fix it by opening up the board and putting a couple of drops of deoxit on the troublesome encoders, or you can replace the whole control board and not have to worry about it any more, which costs US$400 http://store.davesmithinstruments.com/p ... php?cat=13
- Jabberwalky
- Gear:A hybrid of vintage and modern junk
- Band:Variar
The first batch of Poly Evolvers, and MEKs all had this. I did the Deoxit procedure twice to mine. I eventually ended up getting a PE version, which is infinitely better.
