Hello everybody - long time lurking, first time posting - hope you can help.
I am trying to get hold of the factory sequence data for the DMX. I've tried the file over at the wonderful Electrongate. Alas, it says it's corrupted when I play it into the unit.
I've been searching and searching. Does anyone have a working wav of the data?
Oberheim DMX Factory Sequences
- madtheory
- Real name:Tomas Mulcahy
Re: Oberheim DMX Factory Sequences
You're talking about the cassette data save/load right? Are you normally able to save and load sequence data? Could be just the level coming from your computer. It can be hard to get right.
Yeah - do you think it's just a case of trying different levels? I haven't tried saving/loading other data - just the factory file I sourced at electrongate. I did fiddle about a fair bit trying to get it to register but if it's a bit fussy, maybe I'll have another crack with the file I have this afternoon... Thanks, I'll keep you posted.
I have the original, factory sequences on original DX branded cassette tape. it is dated by the manufacturer December 11 1984. If you need or want this contact me at [email protected]battt wrote: ↑Fri Sep 02, 2016 3:55 pmYeah - do you think it's just a case of trying different levels? I haven't tried saving/loading other data - just the factory file I sourced at electrongate. I did fiddle about a fair bit trying to get it to register but if it's a bit fussy, maybe I'll have another crack with the file I have this afternoon... Thanks, I'll keep you posted.
